When importing a NEU file through Hoops Exchange, the model rendering differs from other software. Are there any configurable parameters to ensure accurate display of the results?
27.zip (9.3 KB)
Hello @18234083588,
This seems to be a bug in HOOPS Exchange. I see the log return warnings about skipped faces
WAR - Skip 4 faces during tessellation
Also, this issue did not reproduce after I saved the NEU file again using CREO 8. Attached is the resaved file for your reference.
27_creo8.zip (65.2 KB)
I will send you a personal message with instructions on how to create a ticket using our support portal. Thank you.
Best Regards,
Man
