My font isn't showing up in HOOPS Communicator
If your font isn’t showing up like it should there’s a pretty easy way to fix and troubleshoot this using three of the Converter command-line options.
  1. --output_model_info
    This command will output a text file that contains the specific fonts that may be missing.
  2. --prc_font_directories
    This option allows you to specify where to find these fonts.
  3. --substitution_font
    This final option can replace your current font with a new one if you want to change out the font.
