1 。.case to .cgns
D:\Temp\Ensight\wing\wing.case
vis_StateDatadv: ierr= 1
SYS_ERROR_VALUE Argument with an improper value
ix[0]= 53122
Exported D:\Temp\Ensight\wing\wing.cgns successfully.
2 .cse to .cgns
vdm_FLUENTLibOpen: ierr= 12
SYS_ERROR_FORMAT Improper or incomplete file format
filename= D:\Temp\Case\fluent2.cas
vdm_DataFunOpenFile: ierr= 12
Problem opening file D:\Temp\Case\fluent2.cas. The detected file type is SYS_FLUENT_MESH.
vdm_LManOpenFile: ierr= 12
file= D:\Temp\Case\fluent2.cas
Error: opening Import file D:\Temp\Case\fluent2.cas
.cse.h5 to cgns
vdm_NASLibOpen: ierr= 6
SYS_ERROR_FILE File access failure
No nodes defined
vdm_DataFunOpenFile: ierr= 6
Problem opening file D:\Temp\Case\demo.h5. The detected file type is SYS_NASTRAN_H5.
3 .msh to .cgns
vdm_LManOpenFile: ierr= 6
4 msh to cgns
