What may be the reason why the text on the drawing disappeared when setting up the worksheet?
The following image shows the drawing after rendering, and the text can be displayed normally.
When I activate a sheet,the text on the drawing disappeared.Like the picture below.Changing the background color of the sheet also invisible
What are the possible reasons?
Thanks
Hello there,
There may be multiple causes for this. I think we’d have to look at your code to get a better idea. Can you upload it? If you don’t feel comfortable here I can reach out via email and get it directly.
Hello @619944680,
Just as a quick suggestion, if the source file is a DWG file, perhaps you can load it in Autodesk TrueView (as a way to confirm how the Sheet in question is expected to render).
I am trying to load it in Autodesk TrueView, to confirm how the Sheet in question is expected to render.
Thanks,gabriel :grin:
Thanks. This is a great suggestion, and I am trying it out
