Generating Visualize 3DF Project Build Files
With the release of 3DF 30.40, project files are no longer included in the customer packages. The package includes CMake files which can be used to generate the build/project files you need. CMake is an open-source, cross-platform tool. You will need to download / install CMake - Upgrade Your Software Build System (at least v3.31).
After downloading the 3DF package, you can generate build/project files using a cmake command like the following;
cmake -S . -B ./build -G "Visual Studio 16 2019" -DCMAKE_BUILD_TYPE=Release
Basically, this command generates Visual Studio 2019 project files in a directory called build.
For more detail including usage on other platforms, please review the README.md included at the root level of the 3DF package.
I created a BATCH file (Windows Only) that you can use to generate project files.
  1. Extract cmake_build_2019.zip to HOOPS_INSTALL_DIR
  2. run cmake_build_2019.bat
If run successfully, Visual Studio will open solution with the projects files generated.
If you need to generate hio_exchange project, you can set variable on batch file and turn ON setting -DH3DF_USE_EXCHANGE=ON ^
cmake_build_2019.zip (764 Bytes)
