I’m evaluating HOOPS ACCESS with a trial license. For this evaluation, I’m using CentOS Stream 10 on WSL and CMake 4.2.0. I’ve followed the instructions at Set Up Your Environment — HOOPS Access documentation but I get the following error when I run the example bumper test:
~/HOOPS_Solve_Access_Mesh_Eval_2.12.1_52f38eb1/build$ ./bin/vdm_exam1 ../src/sam/vdm/exam/bumper.unv
[DSYSysNLS][ERROR] Missing or invalid ‘SUPPLANG_V6’ file => Falling back to default locale settings
LICENSE ERROR: ierr= 15
SYS_ERROR_LICENSE Failure when checking License
Missing valid Tech Soft 3D license for this HOOPS toolkit
The license is copied verbatim from Tech Soft 3D Developer Zone → “View your license” (when signed in) and pasted into src/sam/hoops_license.h. The cmake commands are cmake --preset=Linux .. in build and cmake --build .
Another comment is that I get warnings related to libraries being not detected, but they are at most warnings.
CMake Warning at CMakeLists.txt:247 (message):
- Intel Message Passing Interface (MPI) not detected and will be disabled by default!
This can be manually overridden by enabling CEE_SAM_OPTION_INTEL_MPI and setting
CEE_SAM_OPTION_INTEL_MPI_INCLUDE_DIR and CEE_SAM_OPTION_INTEL_MPI_LIBRARY_DIR
to your locally installed Intel MPI
-- - Intel OpenMP version 201611 detected
CMake Warning at CMakeLists.txt:269 (message):
- Intel Threading Building Blocks (TBB) not detected and will be disabled by default!
This can be manually overridden by enabling CEE_SAM_OPTION_INTEL_TBB and setting
CEE_SAM_OPTION_INTEL_TBB_INCLUDE_DIR and CEE_SAM_OPTION_INTEL_TBB_LIBRARY_DIR
to your locally installed Intel TBB
CMake Warning at CMakeLists.txt:280 (message):
- SAMCEF not detected and will be disabled by default!
This can be manually overridden by enabling CEE_SAM_READER_SAMCEF and setting
CEE_SAM_READER_SAMCEF_INCLUDE_DIR and CEE_SAM_READER_SAMCEF_LIBRARY_DIR
to your locally installed SAMCEF
-- - Current Abaqus ODB API version: 2025
-- - Abaqus ODB API version 2025 HotFix 1 detected
CMake Warning at CMakeLists.txt:312 (message):
- Ansys AUTODYN not detected and will be disabled by default!
This can be manually overridden by enabling CEE_SAM_READER_ANSYS_AUTODYN and setting
CEE_SAM_READER_ANSYS_AUTODYN_INCLUDE_DIR and CEE_SAM_READER_ANSYS_AUTODYN_LIBRARY_DIR
to your locally installed Ansys AUTODYN
CMake Warning at CMakeLists.txt:323 (message):
- Altair H3D not detected and will be disabled by default!
This can be manually overridden by enabling CEE_SAM_READER_ALTAIR_H3D and setting
CEE_SAM_READER_ALTAIR_H3D_INCLUDE_DIR and CEE_SAM_READER_ALTAIR_H3D_LIBRARY_DIR
to your locally installed Altair H3D
CMake Warning at CMakeLists.txt:334 (message):
- Ansys CFX not detected and will be disabled by default!
This can be manually overridden by enabling CEE_SAM_READER_ANSYS_CFX and setting
CEE_SAM_READER_ANSYS_CFX_INCLUDE_DIR and CEE_SAM_READER_ANSYS_CFX_LIBRARY_DIR
to your locally installed Ansys CFX
CMake Warning at CMakeLists.txt:345 (message):
- MUMPS not detected and will be disabled by default!
This can be manually overridden by enabling CEE_SAM_READER_MUMPS and setting
CEE_SAM_READER_MUMPS_INCLUDE_DIR and CEE_SAM_READER_MUMPS_LIBRARY_DIR
to your locally installed MUMPS
CMake Warning at CMakeLists.txt:356 (message):
- StarCCM not detected and will be disabled by default!
This can be manually overridden by enabling CEE_SAM_OPTION_STARCCM and setting
CEE_SAM_OPTION_STARCCM_INCLUDE_DIR and CEE_SAM_OPTION_STARCCM_LIBRARY_DIR
to your locally installed StarCCM
-- - DPF version 2025.2.pre0 detected
CMake Warning at CMakeLists.txt:378 (message):
- FFmpeg not detected and will be disabled by default!
This can be manually overridden by enabling CEE_SAM_OPTION_FFMPEG and setting
CEE_SAM_OPTION_FFMPEG_INCLUDE_DIR and CEE_SAM_OPTION_FFMPEG_LIBRARY_DIR
to your locally installed FFMPEG
-- - GLEW version 2.1.0 detected
-- - FreeType version 2.13.3 detected
CMake Warning at CMakeLists.txt:410 (message):
- Hoops Exchange not detected and will be disabled by default!
This can be manually overridden by enabling CEE_SAM_OPTION_HOOPS and setting
CEE_SAM_PACKAGE_HOOPS_DIR to point to your locally stored Hoops Exchange
-- - METIS detected
-- - GKlib detected
-- - Blosc version 1.21.6 detected
-- Checking for module 'mpi-c'
-- Package 'mpi-c', required by 'virtual:world', not found
CMake Warning at CMakeLists.txt:461 (message):
- MPI not detected
Thanks; HOOPS ACCESS looks promising so looking forward to making it work.
