HOOPS Visualize HPS supports many Image Formats (3DF Image Formats). However, HOOPS does not support every possible image format (e.g. gif, TIFF, ico, etc.).
If your application needs to import a format which is not directly supported by HOOPS, you have a few options.
- Convert the file to a format supported by HOOPS and read the converted file
- Enhance your application to read the unsupported format directly and pass the information to HOOPS
- For HPS, use an ImageKit (cf. SetData) when you obtain image data without using Image::File::Import
- For 3DF, transfer the image data to an array of image pixel to insert an image.
