How-To: Set up HOOPS Visualize HPS MFC_Sandbox to work with HOOPS Exchange API
HOOPS Visualize sandbox works with HOOPS Exchange integration as this page.
When you want to use HOOPS Exchange API directly in sandbox, you will need to load and initialize HOOPS Exchange library as followings.
Initializing HOOPS Exchange — HOOPS Exchange 2022_SP2 documentation
Instructions for HPS_MFC_Sandbox
  1. Open the project properties from Visual Studio with a right click
  2. Navigate to C/C++ → General and add $(HEXCHANGE_INSTALL_DIR)\include in Additional Include Directories
    HEXCHANGE_INSTALL_DIR is a environment variable. Its value must be the root of a HOOPS Exchange package before launching Visual Studio.
  1. Navigate to C/C++ → Preprocessor and add USING_EXCHANGE in Preprocessor Definitions
  1. Navigate to Linker → Input and add hps_sprk_exchange.lib in Additional Dependencies
  1. Add include and define the macro in CHPSApp.cpp
#define INITIALIZE_A3D_API
#include <A3DSDKIncludes.h>
  1. Add the following code to CHPSApp::InitInstance() to load and initialize HOOPS Exchange library
A3DBool loaded = A3DSDKLoadLibrary(bin_dir.str().data());
assert(loaded);
A3DLicPutUnifiedLicense(HOOPS_LICENSE);
A3DStatus result = A3DDllInitialize(A3D_DLL_MAJORVERSION, A3D_DLL_MINORVERSION);
assert(result == A3D_SUCCESS);
  1. Add the following code to CHPSApp::ExitInstance() to terminate and unload the library
#ifdef USING_EXCHANGE
		A3DDllTerminate();
		A3DSDKUnloadLibrary();
#endif
  1. Add include A3DSDKIncludes.h in CHPSView.cpp
  1. Add your code to CHPSView::OnUserCode() with HOOPS Exchange API
