Hello, we have an issue (since 2016 oem for real) with the background print.
It seems that if I print with this option enabled, the print doesn’t work.
If you use the publish command, this option is checked by default, and the only way to make the publish work, is to uncheck the Print in background option.
Did someone had the same issue?
