Troubleshooting with using HPS.Exchange in C# WPF Example
Im using the C# example "hps_wpf_sandbox_v140) with exchange.
I can not load a file with exchange, because HPS.Exchangel.File.GetFormat throws an exception “failed to load Exchange libraries”
“at HPS.Exchange.File.GetFormat(String in_file_name) in C:\jenkins\workspace\hps\hps\build\win64_v140d\internals\hps_sprk_exchange\source\cs\HPS.Exchange.cs:line 17983”
Hello, that must be a simple problem of access to the HOOPS Exchange DLLs.
I recommend you to double check your project configuration using this guide:
https://techsoft3d.atlassian.net/wiki/spaces/KBHV/pages/767918478/How-To+Set+up+HOOPS+Visualize+HPS+WPF+Sandbox+to+work+with+HOOPS+Exchange+integration
Especially last section:
  1. Make sure the HOOPS Exchange DLL are in the PATH or near the application executable:
  2. by using the environment variable HEXCHANGE_INSTALL_DIR. Its value must be the root of a HOOPS Exchange package
    2.OR*
  3. by copying the content of HOOPS_Exchange/bin/win64 inside HOOPS Visualize bin directory
I hope it helps!
thanks, this solved my problem
